P3 Advanced or P3 4K?
Discussion in 'Standard/4k Discussion' started by Jakemn, Jan 10, 2016.
  1. Jakemn
    Is the only difference the upgrade in the camera from the P3 Advanced to P3 4K?
  2. mandalay
    That's not it. P3 4K is the same as P3S with 4K camera. It does not have Lightbridge like P3A/P.
  3. Jakemn
    Ok Thanks. Would you recommend P3 4K or P3 Advanced? I previously owned a Phantom FC40.
  4. LuvMyTJ
    LuvMyTJ ADMINISTRATOR
    Staff Member
    Live! From New York!
    It is a pleasure to welcome you to the Phantom Pilots forum Jake. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
    The P3 Standard & 4K are comparable and use wifi transmission.
    The P3 Advanced & Pro use Lightbridge for transmission.
    At this time DJI has the best system with Lightbridge. No one else can compare to that.
    Wifi is inferior to LB so that is a big consideration when buying one. If I had a budget that included a LB model it is a no brainer, get the LB model so the Advanced or Pro should be on your radar. :)
  5. mandalay
    I would get the Advanced for sure.
  6. Jakemn
    Thanks. So just to be clear, the P3 standard and the P3 4K are the same except for the camera? So the P3 Advanced is a better option?
  7. Dirty Bird
    Glen Burnie, MD - USA
    Advanced all the way. Lightbridge over Wi-Fi hands down...5x range.
  8. LuvMyTJ
    Staff Member
    Yes sir! :)
    Especially if you don't have a high horsepower computer to handle the 4K footage.
  9. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Check out DJI's comparison to view the specs side-by-side.
  10. peter west nz
    2k7 is good video, and also good enough to take frame grabs from for stills.
Similar Threads - Advanced Forum Date
Problem with my New Phantom 4 Advanced plus Phantom 4 Discussion Today at 3:24 PM
Filming Eclipse with P3 Advanced Pro/Adv Discussion Yesterday at 1:42 PM
Can Litchi support time lapse on P3 Advanced? Control (Go, Litchi, etc..) Yesterday at 9:37 AM
lost phantom 3 advanced Lost and Found Saturday at 2:23 PM
Phantom 3 Advanced controller upgrade Pro/Adv Discussion Wednesday at 5:44 PM
