I've seen those introductory videos. They're good as far as they go, which isn't all that far. Check this video out. Lots of good advice for beginners: http://www.youtube.com/watch?v=P3E2pQnEDRI
PF
PF
PhantomFan said:LeoS said:Keep in mind that the phantoms are fly-by-wire device. IT relies 100% on sensors itself anyway. GPS, gyro, altimeter won't work less reliably the further away they are located from the pilot. Although there are potential interference sources to watch out for.
Although you say the Phantom is fly-by-wire, that is not true. It is fly by PILOT by radio. The problem as I see it is reliance and interpretation. You can't really rely on the "instruments" without already knowing how to fly from the controls first. Also, it takes more than a bit of time to know where to look to instantly find the precise information you need to make that critical stick decision, too. Look at the folks who transition from line of sight flying to FPV. They initially find it unnatural and struggle quite a bit, and we are USED to using our eyes all the day long. The OSD data is far more non-intuitive at the outset at least.
My advice stands. One MUST develop stick skills first, then increasing reliance on the data stream from the PV has actual meaning and benefit. Only THEN can it be successfully integrated into your flying.
PF
