P2V+ - No control over camera tilt - SOLVED
Hi all,
Sorry, I'm a bit of a newbie, so this might be an easy fix..haven't figured it out.
I have a P2V+. I'm using a Samsung tab for my camera view. The camera is locked into position at 0 vertically. When I go to try to pitch the camera down using the down arrow, the Camera Pitch Control shows the square at the top of the range, but the square is red. using the arrows have no effect on the camera. the camera works fine, records etc. But I can't change the vertical pitch?
Thanks for any help,
Cheers,
Troy
Reactions: JKaddouri
Hey, thanks for the response...I actually just solved my problem. For any others that might have this problem. I have a V2. In the assistant software, under Basic/RC Tab, the transmitter version was set to Upgrade Version. I switched it back to Basic Version, and everything worked fine!
Glad you got it. Enjoy flying.
