P2V+ No Canbus for 2.4ghz datalink ground station install
Discussion in 'Phantom 2 Vision + Discussion' started by rtachna, Oct 2, 2014.
  1. rtachna
    Can anyone tell me where can I find the CANBUS on P2V+, I want to install the 2.4ghz datalink ground station and I dont find where to connect it. Usually they come in one of the legs, not in this case, or is there any other way to install it?
  2. DownunderPhantom
    Grafton, New South Wales, Australia
    Re: P2V+ No Canbus for 2.4ghz datalink ground station instal
    The CANBUS port is found on the main board, it is a white 4pin connector with the label "CAN".
    You will either have to modify the cable from the DATA link or buy the external CANBUS port and connect that to the internal CAN port on the main board.
    There is a very in depth thread on how to do the cable mod and connect the DATA Link to the Vision Plus.
  3. varmint
    Hillsboro, OR
    How is it that the 2.4Ghz video feed on the Vision and Vision + plays nice with the 2.4Ghz data link?
  4. job2310
    Bristol, England
    Buy the external CANBUS port, that's the cleanest install. I've done this myself and it works perfectly fine. To limit the impact of interference with the 2.4 video feed I've followed the guidance on phantommods.info and installed WebUI on my repeater and on the Phantom so that I can change the channel the video feed is using. It's worked fine for me so far although I haven't done much with iPad ground station other then a couple tests.
  5. ToThePoint
    Antwerp, Belgium
    As the phantom uses mostly channel 1 ( ones seen it used channel 11 ) and the videodownlink set on channel 14 ( upper channel ) the chance of them interfering is minimal. But a other device ( unknown ) using channel 14 or 1 could still cause issue's. The 5.8Ghz band is not commonly used ( yet ) so the chance of any interference on that is much less.
  6. rtachna
    Thanks, I've been searching tor the external CANBUS port, and I cant find it, do you have an idea where to find it?
  7. job2310
    Bristol, England
    This is what you need http://www.uavdirect.com/Phantom-2-CAN- ... canmod.htm you can simply unscrew it from the spare leg and put it on your pv2+ and attach the can-bus cable to the main board where is says "CAN"
  8. whoss
    Is the videodownlink set on channel 14 or does it search in the unlicensed portion of 2.4Ghz looking for the best signal? I can't find anything documented that talks about which channel the video link is set on.
Similar Threads - P2V+ Canbus 4ghz Forum Date
P2V+ flight totals? Phantom 2 Vision + Help Yesterday at 4:23 PM
p2v+ gimbal motor drivers replace with p3standard? Phantom 2 Vision + Mods Tuesday at 3:39 AM
UPDATED w/ PICS: A bunch of brand new P2 & P2V+ Parts, dist. priced Classifieds Aug 7, 2017
P2V+ camera gimbal conversion to selfie stick Phantom 2 Vision + Mods Aug 5, 2017
How to use good P2V+ camera for photo stabilized shooting? Phantom 2 Vision + Discussion Jul 22, 2017
