P2V+ Gimbal Potentiometer Question
Hi everyone, i really appreciate this forum as it has helped me tremendously in the past. Does anyone here know where i can buy the solder on pitch control potentiometers? Any help would be appreciated
Its an alps part and its a 10k surface mount. You can purchase it from Mouser.
Jeremy
Hey Jeremy, Thanks for the reply, however when i search for 10k surface mount at mouser i still can't find the right one. Do you have a part number or link you could send me? I owe you one man... thanks
Here you go.
688-RDC506002A
RDC506002A
10K ohm 4mm dia
Thanks a bunch... Btw Jeremy. What do you charge to repair a vision + gimbal camera? I have one that i might need your help on. Thanks
Hey jeremy.... just wanted to see if you have any pointers. ;) I have just rebuilt my v3 camera/gimbal. I put new pots in... be4 the newer pots it had the traditional gimbal shake. Now the gimbal is stable but the cam motor is buzzing sightly. Any ideas?
More than likely you have a motor that has gotten weak from the rapid twitch. Make sure that your motor plugs and ribbon cable are fully seated and clipped. On the rare occasion I get factory potentiometers with a bad surface and it will cause this issue. It can also be the motor controller and that can be a pain, and must be replaced.
Jeremy
