P2V+ DNG white balance
Discussion in 'Editing (Photo and Video)' started by manny, Mar 4, 2015.
  1. manny
    Norway
    I noticed a weird thing on my Phantom .dng-files and was hoping to get some input from you guys, wether it's just my model. I have a Vision 2 Plus v2, and take photos in DNG with the default settings, except for setting the format to .dng.
    The white balance is set to a regular temperature (3500-8000), regular in snowy conditions anyhow. What I find odd is that the tint of the camera is very far out on the magenta side. Usually the tint varies from -10 to +10 in my cameras, but the files from the V2+ is over at +139, which is very extreme when the scale maxes out at +/-150.
    I've shot in non-snowy conditions too, and find my tint around +125. The difference in tint seems to be +/- 20, which is normal, BUT it should be around the zero mark, not +130.
    See this screencap from a photo I took the other day:
    Other P2V+ owners, do you experience the same thing? It is not a very big problem, but it does point out that something is not exactly as it should, and could probably cause minor difficulties in post on special occasions.
  2. jason
    Commerce Twp,MI
    That triangle in the upper left corner should by black in the tools panel and if you adjust the black slider that will take care of it. Did you use the eyedropper to correct WB that should help take out some of the blue.
  3. 4wd
    4wd
    North York Moors
    It's normal and a 'feature' of the camera not a fault with yours.
    In practice no need to worry about it.
  4. Brent10
    Oklahoma
    I notice a magenta cast in some of my pics and in some of my vids (P2V+v3). And for some reason my video editor multiplies the magenta upon rendering.
  5. manny
    Norway
    I usually use the eyedropper tool to adjust WB, and LR takes care of it usually. Still, I find it odd that it is centered around +140 instead of +/- 0, like it should.
    This could easily cause problems for a beginner using automatic features of different programs, which could cause a heavy magenta cast to photos and videos.
    It's not exactly a big problem, but it is very odd.
Similar Threads - P2V+ DNG white Forum Date
P2V+ flight totals? Phantom 2 Vision + Help Friday at 4:23 PM
p2v+ gimbal motor drivers replace with p3standard? Phantom 2 Vision + Mods Aug 15, 2017
UPDATED w/ PICS: A bunch of brand new P2 & P2V+ Parts, dist. priced Classifieds Aug 7, 2017
P2V+ camera gimbal conversion to selfie stick Phantom 2 Vision + Mods Aug 5, 2017
How to use good P2V+ camera for photo stabilized shooting? Phantom 2 Vision + Discussion Jul 22, 2017
