.However do not!!!! upgrade the Zen (camera/gimbal) because that will corrupt you gimbal tiling if you do not have the new Tx
brunofcampos said:I should have read this forum before updating..However do not!!!! upgrade the Zen (camera/gimbal) because that will corrupt you gimbal tiling if you do not have the new Tx
I did this upgrade and now my live feed is broken and I can not make it work again. I can take pictures, shoot movies and control the tilt of the camera, but no live feed.
Is there a work around this? Can I go back to the previous version?
Regards
dbooty said:Check your preview quality settings and make sure they're turned down to minimum then relaunch the app.
Not sure if it will fix your problem but these's a new version of the DJI app for your smart phone which you might try if you've not already.
Worth a shot
aartsf said:Upgrade directly to v3.6.
Also upgrade the battery firmware on the upgrade page of the assistant; run this update for each of your batteries if you have more than one.
However do not!!!! upgrade the Zen (camera/gimbal) because that will corrupt you gimbal tiling if you do not have the new Tx.
FA
