- Joined
- May 15, 2014
- Messages
- 77
- Reaction score
- 12
I really liked the inspire1 tab mount so i did a mod to my P2+ TX and put it on it, way better then the other options. I used a 1/4-20 nutsert for the mount to screw in, I think it turned out good..
Hi, it was $22 on ebay, there is no blocking at all ,Its like it was made for it.what did the mount set you back? any issues with it blocking your control sticks?
I would like to do the same to use an 8.9" kindle fire unit and my P2v+ TX. Could you elaborate a little on the nutsert and what and how you drilled the case. I am afraid my technical skills are not nearly as good as yours and would hate to destroy the case. Also what is the mount called so i can look it up on Ebay. Thank YouI really liked the inspire1 tab mount so i did a mod to my P2+ TX and put it on it, way better then the other options. I used a 1/4-20 nutsert for the mount to screw in, I think it turned out good..
Thank You. How and what did you use to drill the case?I used this mod on my P2 also :
http://www.ebay.com/itm/DJI-Inspire...055?pt=LH_DefaultDomain_0&hash=item2c989249ff
Just drill a hole that is a little smaler than the screw. I did find the position by holding the bracket sideways...left and right. Then make a pencil mark at both positions,and draw a line..... Then hold it in the center....Thank You. How and what did you use to drill the case?
Looks very niceMod for my Samsung Tab S 10.5" to "fit" on the Inspire 1 Holder
And If you would post a how to video I will be very grateful. lol.cool solution right there... i'mma give this one a shot![]()
LOL.. just start with with a pilot hole first,"Small Drill" then work your way up to the right size.Yes, until I start drilling holes, lol.
Thanks I may end up there anyway if this doesn't work. I found this here on the site. If it does not work, I am out 40 bucks and will be forced to drill holes. Here is the mount I found:LOL.. just start with with a pilot hole first,"Small Drill" then work your way up to the right size.
What Tx do you have, The new one with the tilt wheel on the side or the old one ?Thanks I may end up there anyway if this doesn't work. I found this here on the site. If it does not work, I am out 40 bucks and will be forced to drill holes. Here is the mount I found:
Satechi® Dashboard Mount Universal Tablet Car Mount Holder (for 8.9" - 11" Tablets) iPad, Nexus 10, Samsung Galaxy Tab 8.9", Samsung Galaxy Tab 10", S
