P2 FPV - For A Beginner
Discussion in 'FPV (First Person View)' started by Bannister19, Mar 30, 2016.
  1. Bannister19
    First of all, I'd like to say that I did search the forum, read the stickies and all and it helped, just want to make sure I'm doing the right thing before I drop a few hundred.
    I have a Phantom 2 with an H3 3D gimbal (with a Hero 4 Black though, which has worked fine).
    I don't have a soldering iron and I wouldn't trust myself anyways, so I really want to complete it without soldering!
    What exactly do I need to buy?
    Video transmitter. Heard maybe the AVL58 (also heard not that one). Which ever one, do I need RX or TX or both? Link to one that has the required cables and such would be great.
    Monitor obviously
    Antenna?
    DJI FPV Hub?
    Any other cables adapters transmitters? I basically have nothing besides the drone and camera currently. All help appreciated.
  2. jason
    Commerce Twp,MI
    If you haven't already ordered the AVL58 TX/RX system I would suggest looking at either Boscam, Immersion or Flysight for a complete system.. When I started in this hobby 2 years ago I to used the AVL58 system and for plug n play it poorly designed and ended up soldering (hard wiring) instead of using the HUB. Later I decided to cut down on weight so the AVL58 TX had to go as it was to heavy and used to much power as it also had a cooling fan. Not that it didn't do the job because it did. There is a list of the equipment I use posted at the bottom although I do not endorse any brand as being better that another this is what I have been using for better then 1 1/2 years. to Only to items on the outside of the P2 are gimbal, camera and TX as everything else is on the inside the shell.
    #2 jason, Apr 3, 2016
Similar Threads - FPV Beginner Forum Date
A complete beginners FPV kit - Parrot Mambo FPV FPV (First Person View) Jan 13, 2018
A beginner's first foray in to FPV racing drones - what do you reckon? General Discussion Jul 18, 2015
Beginner Questions: First few flights, compass calibration, IMU, FPV? Phantom 3 Help May 13, 2015
Beginner FPV Questions Phantom 2 Discussion Feb 4, 2015
Ghetto FPV / 12v Car Socket (Beginner Questions) FPV (First Person View) Aug 25, 2014
