P2 battery in a Phantom 1?
Discussion in 'Phantom 1 Discussion' started by IMADMAN, May 30, 2016.
  1. IMADMAN
    Is there a way to use a P2 battery in a P1 phantom using only the P1 electrics? Does any one make an adapter that will work? I know the P2 battery will probably not fit in the P1's battery opening, but I don't have an issue running it outside if the shell. Is it too much of a hassle to deal with? Would a better option be selling the P2 batteries and getting better P1 batteries?
    Thanks in advance for any help.
  2. Pilot_FML
    Mentor. Ohio, USA
    Simple answer to your question .... buy larger 3S LiPo XT-60 connector type batteries to accomplish what you want.
    The P2 batteries odd shape, much larger size, much higher weight and unique connector
    don't make it a good candidate for use in the P1.
  3. IMADMAN
    Thanks, just wanted to see if I can use what was at hand.
  4. Phantomix
    Weston, MA
    probably cheaper to just buy a P2 off of ebay or a P3s
  5. IMADMAN
    Not looking to invest in a newer model. Been there done with my rc cars/trucks.
    Just gonna sell or trade off the 2 P2 batteries and charger and get better P1 style batteries
  6. rattydude77
    liverpool ny
    My self I made the phantom 1.5 and I run the multistar 5200 mah 3s and run it as low as 11.2 volts and it bounces back as strong as the first day I bought it
  7. MauTech
    Same ^ as above + have the floureon 5500 batteries but have mine set at 11.3v to be safe
Similar Threads - battery Phantom Forum Date
Phantom 2 Battery issue. Phantom 2 Help Friday at 3:13 PM
Phantom 4 Pro Internal Battery Phantom 4 Discussion Aug 11, 2017
Phantom 4 Battery Phantom 4 Discussion Aug 10, 2017
Maxx Uav Phantom 4 Battery Adapter Clip Phantom 4 Pro Help Aug 6, 2017
Phantom 2 OEM Battery Phantom 2 Help Jul 30, 2017
