Other antennas for my fpv
Discussion in 'FPV (First Person View)' started by PhantomSweden, Sep 13, 2015.
  1. PhantomSweden
    Hi. I am looking for better antennas for my Phantom2, i would like better range/image quality. The setup i have is this:
    Black Pearl 5.8G FPV monitor, DJI AVL58 video downlink transmitter, DJI iOSD Mini, Clover leaf antenna for AVL58 TX.
    I was thinking of getting this from FPVLR, 5.8GHz Premium Combo
    But I do not know what contact I need, its RP-SMA Male or SMA Male? and on the picture there is 3 antennas, but which goes where on the Phantom/remote?
    Anyone with this setup? pictures?
    //Daniel
  2. RoyVa
    Virginia
    What range are you getting with your current set up?
  3. PhantomSweden
    I do not really know, I get interference on the screen almost immediately.
  4. kenjancef
    East Providence, RI
    I do as well, using stock antennas on my Black Pearl, but I'm using an ImmersionRC 600. I just ordered FatShark Spironets, should be in tomorrow. Thing is, it only comes with 2 antennas, and I assume one is for the Immersion, and one is for the right side of the Black Pearl. I'm seeing others using the square patch antennas on the left side of the Black Pearl, but I'd like to understand why it's on the left/how it works and all that before I spend the $$ for it. I just don't want to follow everyone else... if that makes sense....
  5. PhantomSweden
    Yes, I would like to know what to be mounted where and what contact I should have. Asked FPVLR but got no good answer. I'm not good at this, and it becomes more difficult in English for me. I only want good antennas that cope 1-2km without a lot of interference.
  6. PhantomSweden
    Nobody that can help me?
  7. Reflection
    I believe the IRC 600mw uses SMA. For your antenna, you would need the SMA male.
    For the SlySight BlackPearl, I believe it's SMA also.
    From FPVLR's site:
    "The straight antenna and the helix are usually mounted on a Black Pearl monitor with diversity receiver, and have SMA-MALE connectors.*** "
    If you want to go with this product, get the SMA version. Connect the curve antenna to your transmit on your IRC 600mw. And the other two on your black pearl.
    750r likes this.
  8. kenjancef
    East Providence, RI
    I just got a pair of FatShark Spironets, and can confirm that the Immersion and Black Pearl are SMA Female, so if the antenna is SMA Male then you are all set. I ordered a set of adapters just in case, cause I'm still learning about antennas and all that. I still get interference, even with the Spironets, so I initiated an exchange of the Black Pearl. Not sure if that's the issue, but I guess it's a starting point.
  9. PhantomSweden
    THANKS for your answer! know i can place a order!
  10. PhantomSweden
    Thanks, adapters. not a bad idea
  11. kenjancef
    East Providence, RI
    I didn't need an adapter, but if you order, be careful... the picture on Amazon showed 2 adapters, but you only get one. Was surprised by that when I got them...
  12. 750r
    Pa, USA
    Have you tried switching channels on both transmitter & BP ?
    Your other question my BP switches between the 2 antennas R/L
  13. kenjancef
    East Providence, RI
    Yea, I've tried changing channels, no good. And funny thing is, the antennas don't change, no matter what. The blue light always stays on the left side. I can go in and change the mode to Rx2, the right side, but it seems to not help. I missed the delivery of my replacement BP yesterday, so hopefully I can get it today and test it over the weekend.
  14. kenjancef
    East Providence, RI
    Here is a quick example of what I get. The video shows I'm at 121m, but it does the same thing, only not as messy, when on the ground, gets worse as I go up...
Similar Threads - antennas fpv Forum Date
Is anyone selling boosted FPVLR antennas for P3/P4/I1 controller? Classifieds Jun 14, 2017
Phantom 4 with FPVLR long range antennas 2 batteries & extras Classifieds Apr 11, 2017
are the fpvlr antennas worth it Standard/4k Discussion Feb 5, 2017
Phantom 4 controller with fpvl antennas Classifieds Aug 17, 2016
Horizon FPV antennas... Advice? General Discussion Jul 16, 2016
