$40 Argtec + two $5 Windsurfers glued together and fitted to centre 5.8Ghz Omni Argtek supplied antenna ... 4.5kms !!
I'm now looking to boost my video 2.4 further to get it to match better as its now at limits !! That could be by using Omni 2.4Ghz instead of the flat panels .. with Wind surfers as well !! About $20 total for that.
Nice setup Nigel,when I put the Omnis on I'll probably use surfers too,,with the argtek base my options are open to test and try everything,,range is not a problem ,I got no complaints,,just feel the need to tweak things abit,,
