One rotor won't start up
Discussion in 'Phantom 2 Vision + Help' started by andrewmac, Aug 29, 2014.
  1. andrewmac
    Hi,
    I just opened my new Phantom Vision 2 + yesterday, went through the quick start guide, but when I do the in-and-down CSC to start the rotors, one of them (front right) won't spin up correctly. It just spins a couple rotations, then stops, then spins a couple rotations, stops, over and over.
    Here's a video of what I see.
    https://vimeo.com/104730481
    I swapped rotors around and tried the other rotor set, but got the same problem. DJI support told me to return it, but I'm wondering if this is familiar to anyone, and something I could fix myself (without voiding warranty). In the video, you can see the reflection of the LEDs below the faulty rotor, but I couldn't find anything online that says what those might mean.
    Thanks,
    Andrew
  2. Ridetools
    Laguna Beach,Ca
    I have not seen that, but am curious if the bearings might be faulty on that rotor. But you said you swapped it out and the same side failed? Good luck to you.
  3. andrewmac
    Oh, maybe I misspoke. I swapped out the rotor *blades*, but nothing else.
  4. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    Most likely bad motor or ESC. Does it spool u[p when you give it throttle? Regardless, I'd send it back as it will be troublesome further down the road.
  5. andrewmac
    No, it doesn't do anything different when I give it throttle. Already put in for a return.
    (This was a brand new, so it makes me a bit nervous about DJI's quality.)
  6. DDMSteve
    Salt Lake City, UT
    Just a dud motor. Typically if the motor pulses or doesn't start then the motor is bad. If the LEDs on the bottom aren't lighting up it is an indication of a bad ESC.
    If DJI is going to get it sorted out there is no need to worry. Remember that these are hobby model aircrafts after all and replacement parts are sold for a reason. It is a nice thing that they actually have parts you can replace yourself rather than be tethered down to going to a specialty store to fix such a minor problem.
  7. Buckaye
    Orlando
    You might want to switch a known good motor for the bad one and see if you are still having the issue... if you are - than it could be more serious than a motor - if the replacement motor works... than it's the motor. If it's just to motor - I would just buy a new one and see if DJI will send you a replacement motor. Because DJI is so slow - I think replacing the motor would be faster (and then when DJI replaces the bad motor - you will have a spare). Just my 2 cents :)
  8. mikey7
    Hey I bought my phantom vision+ yesterday, I'm having exactly the same problem.
  9. EdwinPJr
    I received my new P2+ yesterday and eagerly set about preparing for first operation and perhaps a flight. My left front motor is behaving exactly like in the video which andrewmac shared. I've done all of the recalibrations and firmware updates, I believe.
    Andrewmac, you wrote that you put in for a return; are turn of what? The entire copter? Or are you being sent replacement parts?
    Thanks.
  10. andrewmac
    EdwinPJr & Mikey7,
    I bought my P2+ from Amazon, so I put in for a return the next day. Amazon sent me an entire new P2+, and it works great. I would suggest you go back to your vendor for an exchange.
    EDIT: Also, thanks to everyone who responded to my initial inquiry so quickly. That was kind of you, and really helpful.
Similar Threads - rotor won't start Forum Date
Quick yellow flashing lights on Phantom 2. Rotors won't start. Phantom 2 Help Jul 23, 2015
Rotors won't start Phantom 2 Vision + Help Dec 13, 2014
3 Blade rotors for P4 Pro+ Phantom 4 Pro Help Dec 17, 2017
Multiple Rotors-Z1 Text Vedio From China, it's so amazing! Photography and Film Sep 4, 2017
The Bigfoot Mount - Rock Solid Tablet Mount by INDUSTRIALROTOR Phantom 4 Discussion Sep 3, 2017
