one rotor not spinning
Discussion in 'Phantom 1 Help' started by bdh6a7, Apr 22, 2014.
  1. bdh6a7
    I tried to fly my Phantom 1 today for the first time in several months. I tried to get the Zenmuse gimbal to work with it last fall, but was unsuccessful and decided to wait for the Phantom 2+. Today only 1 of the rotors would spin. The GPS calibrated without difficulty. I took the Phantom apart and disconnected all of the cables to the Naza. I then followed the video online for the Phantom upgrade to make sure all connections were correct. I then tried to fly again but this time 3 rotors worked, but one rotor did not. All of the connections and solder joints looked good. Any suggestions on what to try next?
  2. tanasit
    Swap the 2 connectors of the problem motor/ESC and the working one/ESC to the NAZA.
    This will test if the ESC and motor combination work on the problem one.
    If the problem persists, then either that ESC or that motor is defective which is more likely than the bad NAZA.
    Also double check the soldered joint of the 3 wires from that motor to the ESC board because many reported some peeled off!
    Good luck
Similar Threads - rotor spinning Forum Date
Slow spinning rotor Standard/4k Discussion May 10, 2016
Rotor spinning intermittently Phantom 1 Help Apr 5, 2014
rotors propeller spinning a different rates Phantom 2 Discussion Mar 4, 2014
Standard different rotor speeds after minor crash Phantom 3 Help Jul 8, 2017
Rust from rotor springs? Phantom 4 Pro Discussion Jun 24, 2017
