I have the
P4P+, I would suggest a couple of things...
First, if you swipe down from the top middle of the screen you will get the Android settings shortcut, pick the gear icon on the top right and go in and do your downgrade from there by picking
"Update", then touch the 3 dots in upper right and pick "Local Update" and you should see the .bin file that you unzipped and put in the root of an SD card.
Second, your Assistant2 is probably not installed correctly, there is a bug with Windows 10 that keeps its driver from being updated due to an improper driver signature. I had the same issue and could not see my RC and I could not calibrate the sensors on my AC. I followed MSingers post and all is well now with Assistant2. Steps below...
1. First un-install Assistant2 from PC.
2. Then follow this procedure
a. Press the
Win + C and click on
PC settings.
b. Switch over to the “
Update & recovery” section.
c. Then click on the
Recovery option on the left hand side.
d. Once selected, you will see an advanced startup section appear on the right hand side. You will need to click on the “
Restart now” button.
e. Once your Computer has rebooted you will need to choose the
Troubleshoot option.
f. Then head into
Advanced options.
g. Then
Startup Settings.
h. Since we are modifying boot time configuration settings, you will need to restart your computer one last time.
I. Here you will be given a list of startup settings that you can change. The one we are looking for is “
Disable driver signature enforcement”. To choose the setting, you will need to press the
F7 key.
3. Install Assistant2 again. Since driver signature enforcement is turned off now the correct drivers will be able to be installed this time
