- Joined
- Aug 12, 2014
- Messages
- 96
- Reaction score
- 0
this morning i went out with a friend and we flew in the town of Bodega. first flight no problem. the sound flight went fine but i noted some droplets of moisture on the shell. there was a small amount of mist in the air and some ground fog in the distance..but i was surprised to actually have some droplets on the upper shell.
i seriously doubt in significant moisture got inside and it flew fine.
we looked for another area for about an hour and both of us had trouble getting a satellite lock when doing the compass dance in the new area.
mine got the green vertically very quickly but nose down it took way longer and took more than once.
we were within 70 ft. of so of power lines..she flew fine but mine just started towing up and take off by itself! i hit both levers to make it stop and avoided it tipping over. now i went to another area and tried it on the ground without props on it. it seems to do the same thing if i move the controls as if to go up and then i notice at times it will speed up by itself.
i thought it was a gps issue so i did imi check and it said it did not need calibration. i then did the advanced calibration for the compass and tried to do the compass dance again..but it did the horizontal calibration fine but it would not do the nose down calibration.
i did notice when connected to the computer the x axis measurement looked like it was going into the negative.
i am wondering if my having a tiny screwdriver in my case that is a couple of inches from my bird screwed with the compass..might this be why it seems to want to take off and not stay at rpm when sitting on the ground after returning the stick to center?
