Odd Flytrex data
Discussion in 'Phantom 2 Discussion' started by joeg1717, Sep 14, 2014.
  1. joeg1717
    I just received my Core 2 the other day and on the second flight i logged i noticed very high altitude spikes. 3 of them when i yawed 360 deg. the spikes were in the range of several hundred feet, when in actuality the aircraft remained at the same altitude . the core is mounted on the right hand side of the body near the rear arm.
    this is the flytrex link to the flight. http://www.flytrex.com/mission/quadcopt ... rdo-70496/ any insight would be appreciated . (i'm uploading the video for the flight now, it will be at the flytrex link )
    thanks
    joe
  2. rrmccabe
    Ankeny, Iowa
    Do you have a picture of where you mounted it?
  3. joeg1717
    here ya go
  4. rrmccabe
    Ankeny, Iowa
    OK well the only things you need to consider are the component on bottom left in your picture is the barometric pressure sensor.
    You went to keep it out of sunlight and out of the prop wash. The changes in pressure will of course make your altitude go crazy.
    Normally its mounted the other way with the microSD card out.
  5. joeg1717
    thanks for the help. i was thinking the instructions said to mount it the other way around.....oops!:)
Similar Threads - Odd Flytrex data Forum Date
Odd Flytrex data General Discussion Sep 14, 2014
flytrex / P3P signal loss / odd startup Pro/Adv Discussion Jan 2, 2016
Odd upgrade behavior ... Am I alone? Phantom 4 Pro Discussion Aug 7, 2017
Something odd after latest FW update Pro/Adv Discussion Jul 28, 2017
Modded Range extender Gets less range after accidental turn on without antenna Connected Phantom 2 Vision Discussion Jul 21, 2017
