I received my 14SG this week, installed the receiver, read the manual and set it up how I wanted. All good so far.
I went out yesterday to make sure everything worked as expected and was generally pleased with the results other than the failsafe function.
I have SC set for GPS, Atti, Manual, which all works fine and I have SF set to force failsafe irrespective of the position of SC. The failsafe activates just fine and the P2 heads for home. However if I then cancel the failsafe (SF back to original position) I get the green lights to indicate GPS mode but I don't get back control of the P2, it just continues and lands as per failsafe protocol.
However, once I have the green lights back, if flick from GPS to Atti and back, I then get control back. I get exactly the same situation if I switch the radio off / on.
Do you other folks using Futaba's have the results?
Cheers
Cheers
