Forward OA uses visual light cameras. In other words you need a minimum amount of light. If there's not enough light for the cameras to see, the OA will not work. In which case you should get a warning on your monitor that says essentially "forward obstacle avoidance blocked or not working". Also, certain third-party applications will override that feature as well.
