Observations from my first experience dealing with NoFlyZones
Pittsburgh-Ish
Just curious to see some of your thoughts on this..
Went to spend part of Easter Sunday with the wife's family, who live near a regional airport here in the US (PA to be exact). So I went into this wondering how it would go calling the control tower to get clearance to fly.
I called the tower on Friday and chatted with a guy there who was pretty helpful, but told me I'd have to call back on Sunday prior to the actual flight and get clearance, fair enough.
Here's a map of the area, showing the DJI No Fly Zone circle..
Now, here's where it gets interesting..
Started at one BIL's house (point 2 on the map) and called the tower as we wanted to fly a Pix4D mapping job.
The folks at the tower asked for the address, but then told me they didn't know where that was and weren't going to look it up. Never asked for my name, FAA registration, or anything else, just wanted to know the maximum altitude I'd be at (I told him 300') and flight duration.
Then they told me "We cannot grant you permission to fly, nor can we tell you no. All we can do is make a note of it to inform other pilots in the area."
Um, OK, so I'm OK to fly?
"Like I said, we cannot grant nor deny permission, but we have noted it here."
OK.. Planes never fly over his house (nowhere near an approach path) so we weren't worried. Flew the Pix4D mission without incident. Spent most of the flight between 150-180 feet, but went up to 299 at the end.
Then we went to my MIL's house (point 1 on the map), and called the tower to update my new location. They were nice about it, but still had the same generic response.
I should note that at this time I had not seen that DJI had an established no fly zone around this airport.
Interestingly, the Pix4d app would crash if I even attempted to set a mapping mission from there, no error, it would just crash and restart.
So I switched to Litchi, where there were zero errors, but I could not fly above 80'. I wouldn't tell me "why" I had an 80' ceiling, it would just stop climbing. As there are trees in the area close to that altitude, I landed and switched to the DJI app.
Once in the DJI app, I realized what the issue was, as it promptly warned me of the no fly zone, and when I hit the 80' ceiling it told me I had "Bumped into a no fly zone".
Again, this is a location where it is rare to see a plane overhead, despite it being near the airport.
But that's fine, I get why the no fly zones exist, and even though I was a bit bummed about it (as I HAD clearance from the tower, or at least communication with them).
But then the curiosity got to me, and we drove over to my other BIL's house (point 3 on the map).
This house is directly on an approach path, and small planes fly within a couple hundred feet overhead every 15 minutes or so.
Let me be clear, I'd be scared to fly here because of this, last thing I need is a close-call with a small plane.
But, to test I called the tower again with the new location to see what they'd say.. And to my somewhat surprise they had no issue with me flying at the new location (point 3), directly on the approach path.
Anyhow, I just thought it was interesting, I was the most restricted in the spot with the least danger, and the least restricted in the spot with the most.. Perhaps the NFZ maps could use a bit of tweaking?
The folks at the airport will NEVER give you permission to fly, but you have informed them, so that's all you can do. As I understand it, a no fly zone is just that, DJI app won't even let you take off. Outside of the no fly, there may be a graduated diameter where the altitude will vary as you get closer or further from the NFZ. You will get a warning as you get close to the graduated area. As far as the approach path, what may look like 300' to you, may be much higher. It is very difficult to judge.
Greetings CRC,
You'd mentioned that you're using Pix4d for mapping. Are you doing this for fun? Great (stop reading this paragraph), but if you're doing something for anything not for hobby, then you're talking about civil Part 107 flying. If you're flying Part 107, you're licensed and you're not calling towers. Instead, you're looking at sectionals to determine what class airspace you're flying in, and if you're in controlled airspace then you'd need a COA , but if not then you're free to fly without calling any towers.
In the case of DJI No Fly zones, assuming your aircraft has the latest firmware, you're working with their DJI GEO system, and the DJI SDK built into Ctrl Pix4 app
which controls your Pix4D mission on your bird will come into play. It will stop all flights inside the 1.5mi red circles and will have a sloping operating cieling radiating out from the red circle to the circumference of the yellow circle. I've attached the DJI GEO map for illustration:
All the best,
Reactions: jvhooser
I've naively flown many times in a NFZ. DJI never refused the flight or limited my altitude lower than the 400' standard. Interesting.
I have now familiarized myself with NFZS and am diligent in observing them. This has definately limited some areas I wanted to video but I understand. When I'm flying commercially every takeoff and landing I'm hoping no one is flying a drone nearby.
Technically, the FAA doesn't recognize or publish NFZs. They have controlled airspace, restricted area and temporary flight restrictions. All of which can and do affect where and when we can fly. The No Fly Zones discussed here are strictly DJI's interpretation. No guarantee that they actually correspond to areas where you cannot fly or that they accurately depict that one exists
What's a NFZ and does it apply if your flying under part 107?
No-Fly-Zones, "NFZ" or now called "GEO System" is DJI's geo-fencing system that DJI which puts flying limitations on their aircraft, e.g. within 1.5 miles of large and small towered airports, prisons, US armed forces installations, war zones, etc., and in affect gives notice to "the operator" that he/she may get in trouble flying within these specific areas. I used the term "operator" purposely, because "pilots" already know where they should or should not be flying That said, Part 107 has nothing to do with this, see my previous sentence about pilots vs operators.. NFZ or GEO System is manufacturer specific, i.e. only DJI products. Search on DJI's website for GEO system, get familiar with it, and if you're doing diligent flight planning it should be no big deal.
WARNING Unknowing Conjecture to follow:
Since some regard these flying cameras as toys, and many people fly them very easily right out of the box, this is DJI's attempt at covering its butt from this potential liability, "...hey we warned the user not to fly, etc...." I guess they don't want their products to go the way of JARTs. (Whoops I just aged myself.) There's a very long long long thread about whether any manufacturer should be limiting a pilots ability to control his/her craft, and I don't want to open that up again.
Fun flights and safe landings,
With the latest FAA and not having to register, does that have any impact on flying in National Parks? Is that still a no no?
Don't see how that would have any effect on restricted areas like national parks.
So "no fly zones" are dependent on the manufacturer, not the faa. Right?
DJI has the capability to lock you out of controlled airspace and no fly zones like TFRs and sports events. Regardless of that, you cannot fly in controlled airspace and into TFRs. Read FAR 101.41 if you're flying as a hobbyist.
I'm working on my 107 right now and have learned about airspace authorizations in the different classes.
argues
