- Joined
- Sep 10, 2015
- Messages
- 443
- Reaction score
- 164
- Age
- 60
Just upgraded the Shield to marshmallow. All works fine apart from the compass which seems to have stopped working altogether. Anyone else upgraded with the same issue?
Thanks for the advice. I've never looked forward to OS updates, always seem to cause more problems. Good luck with the Shield, let us know if anything changes or if you get it sorted out.Yes, done the reset but still the same. I'd hold off upgrading if I were you, until they sort it. It might just be me of course though. Only had a quick flight on Litchi so far, not tried Go yet. Litchi was fine, apart from the map issue linked to the tablets compass, obviously.
Download Field Compass from google play. Turn it off and reboot. Click on Field Compass and wave the tablet about a bit. That usually works for me.On my (new) Shield K1 with Marshmallow, the compass also doesn't work. ****. Any way to downgrade?
Not sure, I tried raising a bit of interest in it on various forums, but didn't get any feedback whatsoever, apart from the Field Compass fix. I'm interested in your roll back - has it definitely solved the problem permanently? Is it easy enough to downgrade ?
Going to try this tomorrow thanksYes I've found the secret is to reboot the tablet, then immediately go into field compass and swish it about a bit. After a few seconds it calibrates, then Go/Litchi maps and radarwork fine and show the right orientation etc. I always use the map locked on true North anyway, but it's helpful to have the phantom icon showing it's accurate orientation and the tablets compass needs to be right in order to do that. Bit of a pain to do every time, but it's now become part of my start up routine. It's good practice to cold boot your tablet anyway, so no real hassle. Hopefully they'll sort this over sensitivity in an update.
I just boot up when I fly, calibrate the compass with field compass and fly.So you have to reboot every time then, Wacker2611? Or do this after every reboot?
I'm back at 5.1.1 and it's great - procedure can be found on https://forums.geforce.com/default/...-by-miscellaneous-app-new-shield-k1-model-/3/
Well, out of curiosity I threw the towel in and rolled back to lollipop. It does appear that the compass is now fine and doesn't require constant recalibration, although it is still very sensitive.I downgraded back to 5.1.1 just now, and the compass calibration problem is gone. The compass works fine, out of the box, and I don't have to recalibrate at all. To me, this is a 6.0 issue, but Nvidia support doesn't acknowledge it (yet?)...
Under 6.0, the compass would only move 10-20 degrees, even if I turned the tablet 180°.
I'll stay with Lollipop for now, but it's crazy Nvidia doesn't even acknowledge this issue in Marshmallow...Well, out of curiosity I threw the towel in and rolled back to lollipop. It does appear that the compass is now fine and doesn't require constant recalibration, although it is still very sensitive.
