Not sure why I'm not seeing the satellite or hybrid option when viewing location of Phantom on iPad. Is there a setting or adjustment within the DJI Pilot software?
That option dropdown is activated by the two layer squares in the right icon right abovePhantom was connected, never saw the choice of the 3 to pick from. Do I have to choose from any settings in menu to display such options? I'm guessing those two layers are the same that are shown in the small box with heading arrow. Clicking the layers doesn't provide the option to choose anything different.
Same here. And I deleted GO before reinstalling in both iPad Air and iPad 4 Mini. Weird.I'm not seeing this on my iPad mini 2. And yes I'm in wifi. This seemed to happen after the update. Only problem I've had with it.
Ok been experimenting-- working good on mineSame here. And I deleted GO before reinstalling in both iPad Air and iPad 4 Mini. Weird.
Sent from my PT beating heart
Yeah i believe you gotta have an internet connectionJust want to confirm first, did you have trouble seeing satellite images during the flight or after the flight when you are back home with Wifi signal? Is your iPad Wifi only model or cellular model?
You only need a wifi or LGE to load the map -- the Go App will cache it. After the have the map loaded. You do not need any internet connection.Yeah i believe you gotta have an internet connection
yes you can bring them up at home and cache the location you are going to fly.Does that mean I should first somehow bring up the maps at home or wherever I have a wifi connection before going to spot I plan to fly it from?
Yes it will work with a phone hotspot.Would it work if I use my phone as a hotspot for the iPad I have connected to the remote?
Yep. Did that but when I hit the squares, the only one that comes up is the satellite. Hybrid or plain map ain't workin! I will hopefully get to mess around with it tomorrow.Ok been experimenting-- working good on mine
1. In the camera view on the screen, touch the map
2. in the map view, touch the right icon with the two layer squares in the top right
3. in the map view the small option screen will drop down with the three map view options.
weird??Yep. Did that but when I hit the squares, the only one that comes up is the satellite. Hybrid or plain map ain't workin! I will hopefully get to mess around with it tomorrow.
