Everything worked fine until I updates both dji and lichi. Now I am not able to connect. Eveything was done as per manual. Installed updated lichi and dji now I get left and right minimal movement from the gimble but I am not able to take off or have any other control because of a "poor signal" and no connection...Are you saying everything worked okay before installing the firmware? Did this issue start right after you installed the firmware? How exactly did you install the firmware? Please be as detailed as possible in your response.
CorrectTo clarify, is this accurate?
- You updated the firmware using the DJI Assistant 2 application
- All went fine with the install
- You flew your Phantom a few times
- You updated both DJI GO and Litchi
- The above issue started occurring
One is solid red, other is blinking greenWhat are the LEDs doing on the rear arms of your Phantom?
