Professional NOSE DIRECTION INDICATOR
Discussion in 'Phantom 3 Help' started by Tecprod, Jan 2, 2016.
  1. Tecprod
    Hello, some times i fly my P3P using a SAMSUNG GALAXY TAB A tablet (android 5.0.2) but i can´t use the red arrow that indicates the drone direction, because this arrow always points the same direccion that points the map arrow no matter where the drone points.
    This cause that i loose the drone orientation.
    When i fly using the ipad3 mini i have not this problem.
    Please help.
  2. Meta4
    Meta4 Moderator
    Staff Member
    For some reason this is quite common with Samsung devices.
    You need to calibrate the internal compass in your tablet.
    Google will show you how to do that.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
  4. flyboyQuad3
    NW KY
    Are the Red LED LIGHTS under the front (nose) motors supposed to stay Red normally? Are the back LEDs the only Aircraft Status Indicators?
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    The front lights should always be red to indicate the direction your Phantom is pointing.
  6. flyboyQuad3
    NW KY
    Thanks.
Similar Threads - NOSE DIRECTION INDICATOR Forum Date
nose of red plane in app different to actual direction. Pro/Adv Discussion Jul 14, 2015
Pilot nose in wrong direction Pro/Adv Discussion Jun 28, 2015
iPad Ground Station nose direction - camera direction General Discussion Nov 3, 2013
DJIs Phantom Forums policy for brown noses Off Topic Jul 17, 2017
Help! diagnose flight data Standard/4k Discussion May 8, 2017
