Professional No Video/No Connection but flies fine
Discussion in 'Phantom 3 Help' started by MAskinut, Sep 21, 2015.
  1. MAskinut
    San Francisco
    I just put my P3P back together after a trip into the ocean. Plenty of details here if you want them (
    Water Damage Tips & Process)
    It flies fine at the moment and everything seems to work except for the video feed. On startup the gimbal goes through its bootup motions as normal but I think there may be something wrong with the transmitter for video and flight data.
    At the top of the screen I get "no connection" but I do have GPS satellites indicated. I don't get any feedback from the drone live. No video, no speed, no distance. Occasionally, I'll get no GPS but that seems to have subsided after a few flights. Generally, my gimbal gets quite hot as well but that seems to have been going on prior to this issue.
    Any thoughts on where to start troubleshooting this one?
    Also, it looks like I nicked this cable on when disassembling. I'm thinking that might be part of the issue.
    http://www.phantompilots.com/attachments/drone_repair9-jpg.31422/
    Thanks In advance!
  2. bobmyers
    San Antonio, TX
    sounds like it may not be reading the SD card
  3. MAskinut
    San Francisco
    I tested two SD's today but no difference.
    Further troubleshooting shows that while the gimbal goes through the boot-up motions it then it goes limp. I don't have the option of taking video or pictures on the screen either and the scroll wheel is not communicating with the gimbal.
    This seems to indicate it might be more than just the wifi module. Does anyone know what these 2 gray wires go to. I'm thinking they may be part of the problem.
  4. bobmyers
    San Antonio, TX
    The picture is out of focus-- maybe you could repost it and point out the wires?
  5. MAskinut
    San Francisco
    sorry about that. Here is a clean pic. It is the 2 gray wires on the middle left under "VCC"
  6. MAskinut
    San Francisco
    I took the gimbal off and connected to a fully functional p3p and same result which takes the wire issue off the table. Narrowing things down, it has power initially but won't transmit video to the RC.
  7. MAskinut
    San Francisco
  8. bobmyers
    San Antonio, TX
    Try reformatting the SD card if you haven't done that already.
  9. Jnnyr
    Hey MA,
    Are you still getting this issue? It recently happened to me and I found the only solution was to do a firmware upgrade. Now it works fine although the new firmware has introduced the 'compass stuck' error.
Similar Threads - Video Connection flies Forum Date
Standard P3S video connection playback error Phantom 3 Help Jul 28, 2017
Standard Losing Video Connection Phantom 3 Help Jan 19, 2017
P4P+: Losing video connection + GPS... What did I do wrong? Phantom 4 Pro Discussion Jan 4, 2017
Lost Phantom 4. Lost video and transmitter connection and it didn't auto RTH. Phantom 4 Help Dec 12, 2016
Lost video connection at 500 meters line of sight Phantom 4 Discussion Dec 10, 2016
