No tilt with gimbal, is there a way of doing it manual
New Zealand
My zenmuse H3-3d is not going properly.The tilt doesn't seem to work, is there anyway I can manually get it to look down rather than horizontal view, which it seems stuck to.
Hi,
Maybe this can help:
-Open the assistant
-Basic RC
-X1 calibration
-move the tilt on the radio
I have had the same kind of problem with my zenmuse H3-2D.
I hope it will work for you too.
Jean-Pierre
Hello, I am a new Phantom 2 owner and I LOVE IT. (until something bad happens).
Spudgun, I had same issue. I opened the transmitter and found that there was an error when someone assembled it. I turned on the TX and Phantom and adjusted the top potentiometer, and what do you know it worked. There is a metal + sign that need to fit in there to control the tilt. I adjusted the tilt to the up-most position and put it back together so they both lined up...DIDN'T WORK!!! Upon closer investigation the POT was smashed down so it couldnt make contact with the stick. I carefully used a good set of needle nose pliers and padding and pulled it back up into place.
I am not saying it is your problem BUT this is what worked for me.
cokersean20
