Not all transmitters beeped when turned on. What color is the led on the tx? There are different versions of the P1.Hi all, I'm a newbie so please be gentle, just bought a phantom 1 and it flies very nice, but i dont hear any beeps at all from the transmitter, even when turning it on........is this normal?.........cheers
I have 3 P1 Phantoms ver 1.1.1. One has red led. It does not beep when turned on. The other two have the green led and beep when turned on. Normally they make no other sounds during operation. If you turn off the quad first ...as you should,,,,but forget to turn off transmitter, it will starting beeping after awhile to alert you.thanks for the reply, the led is red. Transmitter model is SR6
