Hello guys/gals,
Jerry here again with ANOTHER cool trick, I tried, and works beautifully!
( maybe some of you have already figured this out, that is awesome, but this is for those who may want an alternative to ( E-Clips )! And have not gotten this far yet! Thanks! )
No more loose ( E-Clips ): ( or short circuits caused by loose clips! )
I bought these:
Here is stock motor ( E-Clip ):
I used a very small flat screwdriver to remove ( E-Clip ):
Here is the motor without ( E-Clip ):
Here is finished motor with new ( Spring-Clip ) installed:
( NO chance of flying off EVER ! )
Since I know you will flood me with questions about these clips, this should answer most!
You will also need a SMALL size spring clip tool! ( I made my own, out of an old set of needle nose pliers, I used my dremmel, to grind down tips to fit, worked perfectly.
Here is a pic of my professionally made tool:
OK, not so professional, but they work perfectly, and saved me nearly $10. {:0)
So far so good, with new clips, they are also a bit lighter than stock! Several flights with new hardware, no issues, I took it apart after 15 flights, still holding strong! NO MORE WORRIES!
( BYE, E-Clips, have a nice life, been good knowing you, not get out! )
Jerry D
USA
( J Dot )
Take care, Fly safe!
I bought these:
Jerry D
USA
( J Dot )
