No GPS data in exif
Discussion in 'Phantom 2 Vision Discussion' started by panumme, Jan 10, 2014.
  1. panumme
    Norway
    I am very disappointed about the quality of the camera on the vision, and I didn't have high expectations knowing the size of the sensor. Eagerly awaiting the update to be able to shot in DNG RAW format. One of the reasons i bought it in the first place was that it shot RAW files... false advertising!
    However, another issue I'm having is that i don't get the gps data in my exif. not there before or after updating software and firmwares and IOC. (I haven't updated the firmvare on the camera yet, though)
    Anyone have any idea why the data is missing for me? Is there a settings choice that I have altered?
    UPDATE: The vision don't tag the JPG that are created alongside with the RAW file, only if I shoot in JPG mode will the GPS data be in the EXIF.
    Klick on image for the unaltered original file
    [​IMG]
  2. Pull_Up
    South Oxfordshire, UK
    EDIT: The below is WRONG and is based on my particular setup not reporting FULL exif data - the co-ords ARE saved with the standard jpeg and data are are visible if you have the appropriate tool to display it!
    There is none. The GPS is part of the Vision flight systems, not part of the camera. You can fly the Vision in GPS mode without the camera switched on, and you can fly with the camera on but the GPS off (in NAZA mode, anyway). The two systems aren't linked, so there's no data going into the exif.
    This bit is either correct, or less wrong than the above ;)
    Oh and it always did shoot in RAW... just in a proprietary format nothing could read properly! I think the original plan was to have a converter software, but looks like they teamed up with Adobe in order to actually save in DNG. It can't be too far away, the creative director of Adobe has posted an image on facebook he says was taken in DNG with a Vision running a prototype of the firmware.
  3. Bunyarra
    Don't think that is true tbh.
    My imported P2V photos have GPS data embedded and show their location using Lightroom 5's map feature.
    [​IMG]
    http://photosignals.smugmug.com/photos/i-v5ndZSz/0/X3/i-v5ndZSz-X3.jpg
  4. Pull_Up
    Thanks for that guys - like the OP, it seems mine aren't, I had just assumed that was the norm. Having said that, I always import direct from SD card, never via the app - might that be the difference?
  5. Bunyarra
    Nope - I only pull from the SD card. Odd
  6. Pull_Up
    Think I've got it - and it might be a linux issue on my side. None of the standard image properties dialogues ever pulled up GPS data, so I assumed there wasn't any. I've dug a bit deeper and found some specific exif reading tools and.... there are the co-ords! So that's a great new discovery for me! Unfortunately it might not help the OP. I'll dig into this a bit deeper later and see if I can find out why some things are not reporting the exif, and some are in my setup .
  7. jimre
    North Bend, WA
    Some of mine have GPS data, some don't. I think the difference is whether the camera was set to shoot in RAW (no GPS) vs JPEG (GPS). When set to RAW, you can still extract a JPEG image if you use the DJI app to transfer the image to your phone. So perhaps there are GPS coordinates if the camera creates the JPEG, but none if the DJI phone app creates it.
  8. panumme
    Norway
    That might be it. I have always shot in RAW+jpg (the camera creates the jpg file along with the RAW) and and only imported directly from the SD through a card-reader.
    Will try to turn off raw tomorrow and test other ways to import the files
  9. Pull_Up
    ...and if I import them to Google+ they show up with GPS data as well. In my setup, if I look at the image properties I get ISO, exposure time, focal length, all the good stuff, just not GPS. It's there, just my basic image properties dialogue doesn't show it. That's a nice bonus!
  10. pault
    Liverpool UK
    There is quite a neat android app called 'photomap' which automatically finds the photos on your phone and overlays them onto Google maps
  11. juarboleda
    Bogotá Colombia
    The GPS info is in Data Exif, in Photoshop - File - Info File Look this:
    [​IMG]
  12. panumme
    Norway
    juarboleda: thats good for you, but if you open the image in my first post you will see that the gps information is not present. See attached image.
    Did you shot with raw+jpg or only jpg?
  13. juarboleda
    Bogotá Colombia
    Honly JPG, because the RAW format is a Fake
  14. Pull_Up
    panumme can you confirm that when you flew you were in full GPS mode (i.e slow flashing green LEDs, more than 6 sats showing on the app)? If you didn't get a good satellite lock then that might explain no gps data...
  15. panumme
    Norway
    Yes, Pull_up, I can confirm that I always had a good amount of satellites and full GPS mode.
    Today I did test the camera after i switched from raw+jpg to just jpg, and I all the new photos are geo-tagged! :D That means it doesn't include the gps coordinates when shooting in RAW, only in jpg mode.
    I also noticed that lightroom don't even ask to import the jpgs created by the vision along with the RAW. :!: The unusable RAW files may still be tagged with GPS, but no way to verify this.
    I guess it is an photographic habit of mine to shoot in raw+jpg, but i won't be doing that with the vision anymore. I guess I also shot in RAW in hope that there would be a converter awailable soon. I'm not used to dishonest companies as DJI that advertise and market certain features and gets away with it.
    I did not dare to fly today because i was foolish enough to update to an unstable version on the iOS, but kept it on the ground only to check the camera.
Similar Threads - GPS data exif Forum Date
Survey photos with GPS and heading EXIF data Surveying and Mapping Dec 15, 2016
Advanced what is GPS format found in EXIF data Phantom 3 Help Feb 9, 2016
NO GPS or Other Data in Video Metadata Info Pro/Adv Discussion Nov 6, 2017
Reading RAW gps & pitch, roll, yaw data for post processing. Phantom 4 Help Nov 22, 2016
Is it possible to log gps/height level data with the Phantom 2 Vision+? General Discussion Jul 13, 2016
