No Gimbal action after firmware update
Discussion in 'Firmware' started by zinkracer, Dec 2, 2014.
  1. zinkracer
    I was afraid this would happen.
    I have a P2 with the H3-3D gimbal. After installing the 3.08 upgrade and all the other ones, my gimbal is no longer functioning.
    I'll bet I'm not the first to have this problem. Appreciate advice from anyone who knows how to fix it.
    Thanks,
    John Gaither
  2. Damon
    Eastern Wa.
    Explain further, not doing the start up dance (IMU initialization)? Ie: never moving.
    Or doing the first initial movements, but will not tilt when using lever/or dial?
  3. CityZen
    NYC
    By "no longer functioning", do you mean that it stays level, but doesn't pitch up and down when you want it to?
    If so, that's a control issue that's already covered in the P2V+ forum: the control is now relative instead of absolute, and the pitch control needs to be calibrated with the latest RC assistant.
    (No, you can't undo the update.)
  4. zinkracer
    No. It is not responding to anything. Just hangs there like it isn't on - but clearly there is power to the camera.
  5. zinkracer
    Not doing the startup dance any longer.
  6. Damon
    Eastern Wa.
    First check and confirm gray cable is plugged in back of gimbal. Unplug and reseat just to eliminate bad connection.
    Plug phantom into computer and run Phantom Assistant. Post a screen shot here of the update screen showing all your hardware and its current firmware.
    You might have to do a factory reset depending on what is seen in updates page. I'll let you know once I see your screen shot.
    How to Reset a H3-3D Gimbal when bricked or faile…: http://youtu.be/knVigBCbVzU
    How to factory reset your DJI Zenmuse H3-3D gimbal: http://youtu.be/qoy_S6TNX4o
  7. zinkracer
    Screen shot is attached. Thanks for your help.
  8. Damon
    Eastern Wa.
    Did you reset the gray cable to Zenmuse before this screen shot?
    If so you are going to be forced to do the factory reset, since it is not seen in the list of equipment.
    Watch the videos. Perform the task. Once it is seen in hardware you can then upgrade its firmware to a current version.
  9. Damon
    Eastern Wa.
    Notice mine has H3-3D IMU and yours does not.
  10. zinkracer
    OK !! That fixed it. Really appreciate your help. A shame this happens to start with and further shame on DJI that we have to depend on ourselves for these fixes when their own sites ought to have this information. Perhaps I looked in the wrong places on DJI, but I couldn't find one.
    Again, many thanks for your expertise!!
    John Gaither
  11. Damon
    Eastern Wa.
    We unfortunately are their beta testers, technical support, customer support and sales associates. All for free, that makes them smart and us a bunch of dumb a$$3$.
    Glad to hear its up and running ;)
  12. zinkracer
    Good points!
  13. SteveMann
    Westford, MA
    What fixed it? Your response may be a few messages below the one with the working vix.
Similar Threads - Gimbal action firmware Forum Date
gimbal for Möbius Action Cam? Phantom 2 Mods May 8, 2015
Reverse action on Gimbal Dial? Phantom 2 Help Apr 8, 2015
Extraction of battery - damaging to gimbal? General Discussion Sep 12, 2014
H3-3D gimbal with SJ4000 Action cam Zenmuse H3-3D/H4-3D GoPro Gimbal Aug 16, 2014
Sony action Cam gimbal? Phantom 2 Discussion Aug 13, 2014
