Standard No auto RTH with Litchi app P3S
Discussion in 'Phantom 3 Help' started by Mr2lando, Jul 24, 2016.
  1. Mr2lando
    I just installed the Litchi app and saw a warning note. It says something about if control signal is lost the craft will not due a auto RTH. Instead it will go into a hover. This is only for the P3S and P4K.
    Is this true? If so it would be very dangerous too fly any distance away from the home point.
    Sent from my SAMSUNG-SM-N910A using PhantomPilots mobile app
  2. CRF319
    Copied from - Help - Litchi
    Warning - When using a Phantom 3 Standard or Phantom 3 4K (not to be confused with Phantom 3 Pro), be aware that the aircraft will not return to home automatically if signal is lost while Litchi has some or all control of the aircraft, it will hover instead. The following flight modes are affected: VR with Immersive/Joystick Head Tracking active, Follow, Focus and Track. All other aircraft models and flight modes are unaffected by this issue.
  3. Mr2lando
    Does that mean auto return to home will work as long as I am note using one of the listed flight modes?
  4. CRF319
    Yes.
    I use Litchi all the time to fly manual FPV mode and loose signal often due to distance from home point, it comes back every time.
    Edit - I just remembered Orbit mode will not RTH if signal is lost.
    Again copied from the Litchi help page -
    Failsafe
    If signal is lost between the aircraft and the remote controller, the aircraft will continue the Orbit session until it reaches the critical battery level (can be set in DJI Go). It will then land in place automatically, even if your failsafe is Return to Home.
  5. tommi.piiroinen
    I can't find this warning anymore from litchi help page. Is it fixed and RTH will work on all flying modes?
Similar Threads - auto RTH Litchi Forum Date
Litchi going to auto-land after 3 canceled RTH. why? Control (Go, Litchi, etc..) Sep 3, 2017
Litchi "Low Battery" during mission (with good signal) - Auto Land or RTH? Control (Go, Litchi, etc..) Sep 3, 2017
Auto RTH Video Feed - P3P Pro/Adv Discussion Jan 10, 2018
P4P 500m Absolute Altitude limit and Auto RTH Question Phantom 4 Pro Discussion Oct 9, 2017
RTH settings still oversee drone when operating using Autopilot? Pro/Adv Discussion Sep 2, 2017
