I've flown in way colder temps and never noticed a problem. If you're nervous, warm her up inside before going out and keep her low and slow until you're comfortable.hey all, I'm wanting to do a night flight this evening. However is quite cold around 0-1'C
Would it still be OK to fly the drone, taking into consideration previous battery issues?
Was all good, got some good footage tooLet us know how it goes.
Hey mate, it was fine only took her out about 2500ft but operated fine.Remember this, electronics don't take too well to heat, and the same goes for extreme cold. I don't know what kind of components DJI uses but unless they are Military grade they will be effected by the cold as well as hotter temps. I am not saying that you shouldn't fly. Just saying that be careful, and take note how your bird operates. I had mine out yesterday and it seemed to operate a tad bit sluggish at 12 degrees F outside. I did not take too far out because of the cold. I would be curious to know how yours does. There are others here that regularly fly in the cold with no problems. I just know through experience that electronics will act strange at extreme temps one way or the other.
