I'm new to this. My issue is I can connect and fly with no issue. But My wifi says "connected , no internet" Is this why I can't live stream? And how do I fix this?
I am also new to this and had issues connecting, I have found that I have to "forget" the phantom wifi and then reconnect once you get the window saying there is no connection and press ok, that solves the issue. There is a box you can check to not ask again but I always forget to check it. maybe that will keep you from having to reconnect to the wifi.
Hi, it's normal because your Phantom does not provide internet connection, just a WiFi link with your device.
If you want to use streaming feature, you must have a 3G/4G connection.
