Hi, I have been testing the DJ6 RC Transmitters I have and here is what I have to report in regards to the new firmware v 1.0.1.24
The version of Firmware that comes on the DJ6's I sell is 1.0.1.12. When the DJ6 is turned on with this firmware the light is a reddish color and there is no sound from the DJ6.
After upgrading to the new firmware V1.0.1.24 the led on the DJ6 is green and the DJ6 beeps 3 times.
The new firmware seems to work fine with the Phantom but there is a little difference I see. When I check all of my DJ6 units before I ship them I look for 1000 to 1000 on all the instruments. Both sticks and both switchs and the gimbal slider on the back. Quite often X1, the Gimbal control, does not reach 1000 on both sides so I re-calibrate and usually that works. I do see that after I do the upgrade to the new firmware that the 2 sticks, U and X2 only swing from 780 to 780. Now both of those switchs are positive action and have 3 postions and it does seem to work just fine. The gimbal, which is X1 still shows 1000 to 1000 as do both of the sticks.
I have upgraded 4 DJ6's to the new firmware and it seems fine. Now, is there any reason to upgrade to the new firmware? Well it does beep now, but other then that none that I can see. If you have not upgraded I recommend you wait until we see, over time, how this new firmware works.
I do want to address the binding process. I gave incorrect instructions in the past and I wish to correct that. There is no need to either press a button while powering on or hold down any sticks. The process is so very simple and I promise this works as I have tested it on 25 DJ6 units and it works without fail. I used 5 different Phantom V1.x models with the Part 31 Receiver that I also sale as a kit with the dj6.
ASSUMING YOU HAVE REMOVED YOUR PROPELLERS!!
Here is the correct method to bind, no matter what version of firmware.
1. Plug in battery with battery out of quad, the light wiill come on solid red on the receiver in the battery compartment.
2. Turn on DJ6. The led in the battery compartment will begin to blink green.
3. Hold down (or up really) press the button next to the led on the receiver until the light blinks red once or twice, 2 or 3 seconds, then let go.
YOU ARE NOW BOUND TO THE QUADCOPTER. CSC THE STICKS AND THE MOTORS WILL START.. NO PROPS, RIGHT?
link to kit.. I also have a tool kit and 8" propellers...
http://www.ebay.com/itm/291277333111?ss ... 1555.l2649
