Newbie w/ Questions
Discussion in 'Phantom 2 Vision + Discussion' started by FLHarleyDude72, Oct 13, 2014.
  1. FLHarleyDude72
    Heya all - I had searched and I can't seem to find it. My two questions are:
    1. If I go out of range and the RTH kicks in, how do I cancel it during RTH mode? While it was approaching, it ended up landing on my roof and I had no control :lol:
    2. Is there a quicker way to download the photos/videos from the camera to the iPhone? It takes like 10 minutes to do the transfer. :roll:
    a. I did notice a usb port located on the camera base.
  2. pb7424
    Two Rivers, Wisconsin
    To take back control during RTH, toggle S1 switch from GPS to ATTI and then back to GPS.
  3. Dirty Bird
    Glen Burnie, MD - USA
    Question #1 was already answered.
    2 - If you are downloading photos from the app to the phone via Wi-Fi, it is tolerable. If you are trying to transfer large videos, forget it. The connection is just too slow to be useful. You can use the USB port on the back of the gimbal to attack to your computer. Note that the Phantom must be powered on for it to be visible. The MicroSD card in your Phantom will appear as a portable hard drive and you can drag and drop files as you would normally. This is much faster than Wi-Fi and if I recall you will obtain about 11 Mbps transfer speed.
    3 - The fastest way to transfer is to remove the card from the Phantom and insert it directly into your computer. Use an appropriate MicroSD > SD adapter if required. Depending on the speed of your memory card, this method will yield 20+ Mbps or more.
  4. Mako79
    Sydney Australia
    Method 2 over wifi I wouldn't suggest because the phantom gets warm real quick without the props on.
    If you are plugging in a cable, make sure you remove the gimbal clamp. Many forget this because they don't see the warning on the screen. Both of the above methods also chew the phantom battery and therefore lessen the flight times. Losing 5-10% just to transfer files equates to 1-2 minutes of flight time.
    Method 3 is best. I know removing the SD card in out may damage insert/eject slot over time but I don't recall the last time I messed up an SD reader. They seem pretty sturdy on the Phantom.
  5. FLHarleyDude72
  6. pb7424
    Nice landing!! :)
  7. smallman28
    Surprised it landed on the roof.
    When mine does a return to home if it doesn't like the ground it has landed on it flies a few inches across the ground before trying to land again.
    I had assumed it is cause the ground wasn't level enough for it,that looks like what is happening to me anyway.
Similar Threads - Newbie Questions Forum Date
Maiden flight: a few questions by a newbie Pro/Adv Discussion May 9, 2017
Hi everyone! Newbie here.. just a few questions I can't find answers to! Phantom 4 Discussion Mar 11, 2017
Newbie questions Standard/4k Discussion Mar 5, 2017
Newbie from Michigan with questions Introductions Jan 16, 2017
My assorted stupid newbie questions Phantom 2 Vision Help Jan 15, 2017
