Newbie startup issue
Discussion in 'Phantom FC40 Help' started by shaskill, May 20, 2014.
  1. shaskill
    My FC40 at startup blinks green and red twice after a whiel one green one red. I need to get directed in the correct direction to get this new copter going. Thanks
  2. J Dot
    Sarasota, FL. USA!
    Hello,
    I'm not 100% sure, but I believe,
    The single GREEN blink is indicating ( you are in GPS MODE )
    The 2 RED blinks, indicate ( weak GPS signal ) 5 satellites
    Then
    The single GREEN blink ( GPS mode ) same as above
    The single RED blink ( ok GPS SIGNAL ) 6 satellites
    Ultimately you want a single GREEN blink ( GPS MODE ) with MORE than 6 satellites.( no RED blink )
    Maybe another member can confirm! I read the manual, this seems correct!
    I have a P2V, mine is a bit different, but I like to read all the manuals to different
    Models, like to know as much as possible!
    Hope this helps!
Similar Threads - Newbie startup issue Forum Date
Professional Newbie initial startup advice Phantom 3 Help Nov 23, 2016
Hello, I am newbie here. Introductions Thursday at 6:09 AM
Newbie Introductions Jan 15, 2018
Newbie Introductions Jan 14, 2018
Newbie here...Question : Does the GPS/ap automatically disable the drone within FCC proximity guidel Introductions Jan 12, 2018
