Newbie Question re: tablet(s)
Discussion in 'Pro/Adv Discussion' started by Roaddogg, May 9, 2016.
  1. Roaddogg
    I been flying my P3P for about 2 weeks now with my iPhone 6 Plus. I was thinking about getting an iPad mini or other recommended tablet to run the app. If I get one of these do I
    A) need to get one with cellular capabilities?
    B) If so, do I need to purchase a cellular plan?
    Right now I have used my iPhone 6+ in both normal and airplane mode. I'm a bit confused of the pros and cons of both modes, except that will not get distracted with calls or texts while flying with airplane mode turned on (but what am I giving up?). I think in any case I would like something dedicated for the bird. Thanks for any advice.
    Sent from my iPod touch using PhantomPilots mobile app
  2. Oso
    Oso
    Western US
    Hi there. This single post should give you some good info to consider:
    Tablets and phones that work well with DJI GO
    #2 Oso, May 9, 2016
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Other than limiting distractions, using airplane mode will help ensure your phone has more resources available to run the DJI GO app. It's a beast!
    I like the iPad Mini 4, Google Nexus 7 (2013), and Nvidia Shield K1. You can find other recommended and commonly used devices here.
  4. Roaddogg
    Great info... Thanks!
  5. Meta4
    Meta4 Moderator
    Staff Member
    You don't need cellular anything to fly the Phantom.
    Confusion arises because Apple, in their wisdom only fit a GPS to their cellular capable iPads.
    Having a GPS in your tablet is only useful for:
    1. Follow-me flying
    2. Resetting homepoint to the location of the controller​
    These aren't important for most flying for most people and if they aren't necessary for you and you went that way you'd still be flying just fine.
  6. Roaddogg
    Msinger - just to confirm... If I have iPhone 6+ in airplane mode... GPS is still enabled for app/flight? Do you know if anything in the App is disabled when in this mode (I thought I read something about the editor)? Thanks for your input.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Agreed. And, if you do purchase a Wi-Fi only device and you find you need these features later, you could either fly with your phone during those times or get an external Bluetooth GPS receiver.
  8. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Correct.
    Airplane mode turns off cellular (voice and data), Wi-Fi, and Bluetooth. If you need any of those, you can turn them on individually.
  9. Roaddogg
    Thanks Meta... I thought GPS was needed for compass calibration and map location functions...I guess I'm still a bit confused.
  10. Roaddogg
    Ahh... The light is turning on now for me regarding this issue!!! Thanks guys for explaining!
  11. CafeRacer
    You don't need to buy a cellular plan. However, you do need a cellular iPad so you can use the GPS, this will allow the Return to home function to work as well as follow me mode.
  12. Meta4
    Meta4 Moderator
    Staff Member
    Your Phantom has a fine GPS unit of its own and doesn't need another one in the tablet to be able to RTH.
    The only benefit of a GPS in the tablet is to be able to reset home to the location of the controller or to Follow-me.
    Everything else works perfectly without GPS in the tablet.
    GPS is not related to the compass.
    Maps aren't related to GPS.
    GPS only provides location and speed data.
    But the GPS inside your Phantom is the one the Phantom uses for all flight functions apart from the two special cases mentioned above.
Similar Threads - Newbie Question tablet(s) Forum Date
Newbie here...Question : Does the GPS/ap automatically disable the drone within FCC proximity guidel Introductions Jan 12, 2018
Newbie question - Firmware version Phantom 4 Pro Help Nov 22, 2017
Newbie Question - UK Drone Laws Rules and Regulations Nov 1, 2017
newbie here got a daft question General Discussion Oct 28, 2017
100% Newbie Question Again Pro/Adv Discussion Sep 9, 2017
