He's referring to the Phantom 3 STANDARD transmitter which charges via micro usb.Must be the dji phantom controller charger and from my experience so far you have the controller turned off to charge.
Send us a video of what's going on. That will make it easy to diagnose. Are you sure the controller isn't already off and you are switching it on resulting in the red light??When I attach the cable to charge the Controller, the red light to the right of the power switch illuminates.....nothing else. When I turn the power switch on, the green led's start flashing from left to right. When I first turned it on, the first two led's would flash. Now there are three led's flashing. It appears to be charging. Will it charge if I turn the switch off? I can't tell because the green led's do nothing when the power switch is off.
Hmm... are you sure it isn't fully charged? The lights will not come on if it is. Leave it on for an hour or so with it charging and see if the greens go away. If that doesn't work hopefully someone else will see your video on here and give you a better solution. Good luck
It is .Thanks !!!!
Before I connected it, when I turned it on, there were only two green led's illuminated. Now when I turn it on (charger not connected), all four green led's are illuminated. It appears to be charged.
Neat videos on your channel by the way! I also did a light show this past Xmas. Subbed.
Leave the controller off while charging.....and does the controller have to be turned on while charging?
