New Troubleshooting item
Discussion in 'Phantom 2 Vision + Discussion' started by Drone-Outlaw, Feb 20, 2015.
  1. Drone-Outlaw
    United States,Houston, Tx
    OK so this will now be the 2nd time I have had all types of wierd conditions/symptoms on my P2V+ & it ended up being a problem with the Mini SD card!!
    I did a flight and everything was going routine until there was about 36% battery left. Anyway I stopped getting any FPV on the Ipad mini I was using. I landed it and tried out a different battery & same thing...I tried just about everything you can think of & it would not display any video on the FPV. I was getting telemetry only. Upon getting home I checked the Fly-Trex log & it showed that no flight had taken place? I called an expert & he gave me several thing to try, he felt it was a battery issue, or the newest firmware upgrade. I have recently added the Stage IV FPVLR ant mod's & I thought it may lie there??
    Thinking back to a situation I had that was similar to this...(as in nothing was making sense) I recalled the fix for that problem....NEW SD CARD... SO I pulled out the 32 card and popped in a 8 that I had...YATZEE !!!! flew it some then tried out the same 32 card & it produced the same problem, No FPV video & the Fly-Trex not registering. I pulled it and then put in a new 32 card & worked perfect.
    So the SD card should be on the top of your troubleshooting guide when you are stumped! It's easy to do & check.....
    Moose
  2. bbfpv
    Long Island, NY
    what happens if you format the bunk SD card using the App? would be interesting to see if its just a busted card or if there is some data integrity issues causing this that can be fixed w/ a simple formatting. Let us know.
  3. flyNfrank
    Indy, USA
    Nice catch....thanks for sharing!
Similar Threads - Troubleshooting item Forum Date
Fat Shark V3 Troubleshooting Phantom 4 Pro Help Apr 14, 2017
Standard Troubleshooting a couple issues Phantom 3 Help Apr 13, 2017
Standard Newbie requests help troubleshooting Phantom 3 Help Mar 4, 2017
Help troubleshooting gimbal motor overload - I've tried everything Pro/Adv Discussion Oct 23, 2016
Troubleshooting a P3P Board Fire Pro/Adv Discussion Jun 18, 2016
