New phantom stuck in failsafe.
Discussion in 'Phantom 2 Discussion' started by terrylowe, Nov 20, 2014.
  1. terrylowe
    Hattiesburg, MS USA
    I think there is something wrong with my phantom 2….hoping I am wrong.
    I now have 4 flights on it. Two flights ended when it went into failsafe mode by itself and returned home. I was puzzled as my controller battery was not low and both times it went into failsafe when it was within 30 feet and about to land. I brought it in and turned it on just now and the yellow leds were blinking fast. I know this is a warm-up too, so I waited about 20 minutes while it blinked. I then picked up the phantom and rolled it a bit to turn off the battery and it went out of failsafe to normal mode and started looking for a GPS signal.
    I then rolled the bird back over and it went back into failsafe mode with the yellow blinking. When I plug it into my PT2 software, it indicates that it is in failsafe mode. None of the switches on the controller work when it is doing this. The controller was on the entire time with a fresh set of batteries.
    I have not crashed it and all of the landings have been gentle.
    I have all of the latest firmware for the controller and for the phantom.
    Could there be a loose connection that prevents the bird from getting a signal from the controller?
    Terry
  2. Mako79
    Sydney Australia
    I know you cant take off on failsafe.. 50/50 could be the right toggle switch playing up..
    Go into the RC or phantom assist and flick the switches and see if they move the sliders on the screen.
    If they don't...
    Buy a new switch for 3 bucks..
    3 position switch.
    [​IMG]
    Open up transmitter and take photo of the wires for notes. Solder and test in the Phantom assist.
    If you are in urgent need to get airborne, switch the IOC left toggle to the right (leave IOC in the off position). And also see if they unplug from the control board.
  3. Damon
    Eastern Wa.
    My bet is on the receiver and/or its antenna connections. Based on its actions when manipulating the phantom itself.
  4. terrylowe
    Hattiesburg, MS USA
    Tested it and the switch works fine.
    It happens when I roll the phantom over.
    I let it cool off and then restarted it. It came up in failsafe mode. I waited about 5 minutes and then picked up the bird and rolled it on its side. Failsafe mode went off and then it started searching for satellites.
    Do I need to take the top cover off to look for loose antenna connection?
  5. Damon
    Eastern Wa.
    Since its new..I would get it replaced under warranty and not mess with a lemon that failed quality control.
  6. Mako79
    Sydney Australia
    There should be only 1 x 4 pin connector. They come loose easily if bumped.
    Just be careful with the tiny screws on the end of each arm on the phantom. Find a perfect Phillips screw driver as they fray easily.
  7. Damon
    Eastern Wa.
    If your going to take it apart. Research procedure on YouTube. Mako is correct the end Phillips screws are a b@#$&. Unscrew them first, then the arm Allen head screws and don't forget the Allen heads at base of arm next to landing gear. Four Allen screws at base of motors can be left alone since motors don't need to be removed.
    Be careful removing top, making sure to unplug GPS cable.
  8. Damon
    Eastern Wa.
    Check these cables at receiver and track them to MC to make sure they are seated there also.
  9. terrylowe
    Hattiesburg, MS USA
    Problem solved!
    I took the cover off. Thanks for the tips!
    I tracked the antenna wires to what I assume is the receiver module. I removed a connector board on top of it and found a loose screw rolling around on the receiver circuit board. I took the screw out, reassembled it and tested it. Comes on and works like a charm now. When I was tilting the bird, the screw was apparently rolling just enough to short out the receiver circuit board kicking the bird into failsafe mode.
  10. Damon
    Eastern Wa.
    Good job. The bigger question...what is missing a screw now? ;)
Similar Threads - phantom stuck failsafe Forum Date
Phantom 4 Pro Stuck in Beginner Mode Phantom 4 Discussion Aug 10, 2017
Phantom4pro+ DJIgo app sign-in stuck... says "no internet connection" Software Jul 2, 2017
My Footage is stuck in the cache in the Phantom Controller. Phantom 4 Discussion Jun 21, 2017
Mavic stuck in tree, Phantom 3A lends a hand General Discussion Jan 29, 2017
Phantom 4 Device Holder Stuck Phantom 4 Help Dec 2, 2016
