  1. drewji
    Hello guys I was wondering if this is usual or defective battery. I received my new P4. I am trying to charge it but only 2 led green lights up after over 2 hours of charging it. When plugged to the charger all the LED lights are off but when I press the button to check the battery life it on lights up 2 solid green. Is this usual or a defective battery.
  2. Zerome
    Helsinki, Finland
    Charging battery from 0% to 100% should take approx. 1 hour.
    Does it charge battery normally and all 4 led's blinks while u are charging the battery?
    Or do u mean that after 2 hours of charging it still blinks those 2 first leds like there is 50% of power in battery?
    Battery level you see when you press button fast once, 4 led's 75%-100%, 3 led's 50% to 75% and so on.
    Battery life you see when you press and hold battery button for 5 seconds.
  3. WWK888
    Might be the charger or the battery. I take it you only have one battery? Notify DJI maybe they will send you a replacement.
  4. RémyHeli
Similar Threads - Phantom Battery Charging Forum Date
New Phantom 3 Standard - battery question on discharging Standard Nov 30, 2017
New Phantom 4 Battery not Charging, Odd Light-up Configuration Phantom 4 Help Oct 23, 2017
Phantom Controller Battery Charging Problem Solved Phantom 4 Help Sep 2, 2017
Advanced Phantom DJ3 Battery not charging. Phantom 3 Help Jun 23, 2017
Phantom 4 Series - Battery Charging Hub Not Working Phantom 4 Discussion Jun 1, 2017
