New P3 flyer - really limited to 393ft??
Discussion in 'Pro/Adv Discussion' started by John Mueller, Aug 18, 2015.
  1. John Mueller
    I just took delivery of my P3 this past Saturday and was fortunate enough to use it for a wedding I was photographing. I updated the firmware on the controller and plane per the vendor recommendation, and now I'm not able to go above 393ft in any situation. FAA keeps 400ft as a "suggestion" as far as I know and I can see I'm able to specify maximum altitude to 500m which should be well over 1500ft. Am I really limited to 400ft or are there other ways around this? I have no intention on flying through clouds, but certainly I should be fine up to about 700ft or so to get perspectives around mountains, etc.
    Thanks in advance
    John
    Ventura County, Ca
  2. bracKopter
    You have to have the phantom running and connected to your app. Then you can raise max altitude to 500 meters.
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You should also disable beginner mode in the DJI GO app.
  4. John Mueller
    I have my iPhone 5s using the DJI Go app using the latest firmware. I believe I saw the area where I was able to specify maximum altitude from 0-500m, but am not sure it's there with the newest firmware. Even when I had it at 500m, it would still limit itself to about 400ft.
  5. John Mueller
    Disabling the beginner mode.... that might do the trick. I'll have to read-up on what that means and what I might need to look out for. I typically just fly around a couple hundred ft from where I am, always LOS.
    Bag1 likes this.
  6. rwakins
    It was my understanding that it won't let you go higher than 400 ft
  7. sharper4
    Dallas - Fort Worth
    Its that you SHOULDN'T go over 400'. Yes, you can take it to 500 meters in the app.
    But seriously... just fly under the guidelines. Every time you push the envelope just for the sake of pushing it, you put each of us at additional risk for more regulation. Just because you can, doesn't mean you should.
    FunN4lo, bobomet, JohnK and 2 others like this.
  8. John Mueller
    I'm all for safety. I'm also taking this to a couple different countries next month where they don't have these restrictions and want flexibility in my vertical and horizontal range.
    Bag1 likes this.
  9. mick
    and remember 400 ft is from ground level, so if you are in a valley, 400 ft up from there, but if you are on a mountain/hill top that is 2000ft above the valley floor, you can go 400ft above that, so take off from high ground if you want those shots and within the guidelines
  10. III% Streve
    And THAT right there is what makes all the arguments for safety go out the window!
  11. sharper4
    Dallas - Fort Worth
    Actually, I think THAT is what makes it a guideline. It's really up to us to be reasonable and safe, not try to find a loophole. You could go up to the roof of a skyscraper and launch but you know it goes against the spirit of the rule.
    I don't think the OP was actually trying to be unsafe, but then we see almost every day that someone thought it would be cool to fly their drone into the path of incoming aircraft too, just because they can.
    JohnK likes this.
  12. John Mueller
    Exactly right. I work for the military on base and the last thing I would want to do is put the people I work with in danger. My goal is to get the most from my P3 under legal laws. Ethics and guidelines are typically subjective however and best practice may deviate from what the majority believes.
  13. mick
    I certainly wasnt trying to be unsafe, those are the rules, apart from military aircraft no planes are going to be below 400ft from the top of the mountain, nor helicopters, so you are well within your rights to go up a mountain and take off
  14. Recce2
    Duluth, MN
    400ft is twice as high as I can go under the 333 exemption and COA.
  15. JohnK
    Hudson Valley, New York
    OK, I'll bite. What does that mean? I'm happy to stay under 400ft, since I can sometimes no longer see it at that height, and the videos from there are spectacular.
  16. John Mueller
    I just took it out and did some videos of Malibu, but wasn't able to find the "BEGINNER MODE" in the app. Will have to look it up when I get home
  17. herein2014
    Definitely not a 400ft limit. I've been up 1500ft with no problems. Was in international waters no FAA there. Still had 63% battery life, annoying that 500m can't be lifted. Have taken my P2 up 2500' before in international waters.
  18. SouthernPhantom
    If I recall correctly (from my beginner days, last spring), beginner mode lets you go up to 100 feet. The app normally limits altitude to 400 feet (in the US), but you can override it.
  19. John Mueller
    Unless it's hidden somewhere, or if it's because I'm in "P-mode" I don't see where it can be over-ridden to go above 400ft". I have the latest firmware.
  20. Dave Ward
    Atlanta
    Really? I haven't looked at a ton of them, but most of the 333 exemptions I've read mentioned a 400ft limit.
Similar Threads - flyer really limited Forum Date
Luckiest P3P flyer Pro/Adv Discussion Aug 6, 2017
Uk flyers!? General Discussion Jul 9, 2017
NOTAM ? - Rec flyer vs part 107 Rules and Regulations Jun 20, 2017
Careless drone flyer could have killed me General Discussion Jun 16, 2017
New Flyer- Few Questions/Problems Standard/4k Discussion Jun 4, 2017
