New P2 maiden flight - crash...
Wiltshire, UK
Hi,
Received my P2 + Zenmuse H3-3D today.
All set up okay, and did a quick test flight. I couldn't get it to just hover when I took my hands off the controls. It kept drifting in an arc, and at one point just lost power. The battery was 100% at the start, and about 35% when I finally stopped. I'll need to fly it again to see if the drift is always in the same direction.
I managed a couple of crashes. No obvious damage other than scuffs (no chips or dents) to the props.
I updated the firmware before the first flight, and completed the compass calibration.
Has anyone seen anything like this before? Any idea what I should do?
Darren.
Are you waiting for it to get a solid GPS lock? Did you you do the advanced IMU calibration? Are you sure you calibrated the compass correctly?
Hi,
Quick update: I've had full GPS lock on all flights, and calibrated the compass. I went out the other day for another flight and put a new set of props on. I didn't get any problems with that flight. I can only assume that either the props were faulty in some way, or (more likely...) the first crash I had damaged them in some way.
Regards
Darren.
wkflysaphan4
