New P2 - Going to install FPV. Any bulletproof tutorials?
Just purchased a new P2V+ and a P2 along with all the necessary components to install FPV. Any good "for Dummy" tutorials? I'll be installing the HD3D, iOSD, Ground Station and a Black Mamba transmitter on the phantom side. I also have the FPV HUB as it seemed necessary? On the controller I'll be installing a Black Pearl w/ accompany antennas. I've seen a bunch of individual posts by component. Not sure if a soup to nuts tutorial exists? Thanks in advance!
Re: New P2 - Going to install FPV. Any bulletproof tutorials
It's pretty much just plug it in and turn it on, you just need to make sure you have all the connections correct. The gimbal is easy, there's just one obvious 8-strand grey cable on the Phantom that plugs in to it.
For the iOSD mini and Black Manba you don't need the DJI FPV hub, this cable will connect the OSD and transmitter to your Phantom: http://www.dpcav.com/xcart/Video-Cable- ... xtech.html
shimuafeni fredrik
