New legs old legs
Discussion in 'Phantom 2 Vision Help' started by crash1sttime, Mar 14, 2016.
  1. crash1sttime
    Manchester UK
    Hi
    Reading JDot's excellent thread here My complete MOD list, w/ how-to, tips, and tricks!n he states that " p2v version is skinny landing gear, p2v+ version is wide landing gear ", im looking at replacing the open compass with the new shielded unit, but does this mean i have to change both legs?
    dirkclod likes this.
  2. J Dot
    Sarasota, FL. USA!
    Hey crash
    NO, they make both versions, just make sure you don't get +.
    But
    Make sure you read all my post, if you have old GPS you have to swap cables, or upgrade your GPS. It's all In my post.
    J Dot
    dirkclod and Mark The Droner like this.
  3. crash1sttime
    Manchester UK
    Hi J Dot, so I can just buy the one with the modded compass ? I get the need to swap the cable out, this isn't an issue at all thanks
  4. J Dot
    Sarasota, FL. USA!
    Hello,
    Yes, order the P2v version ( skinnier version ) the p2v+ legs are ( wider version ) but the electronics are the same, only legs different on the 2 models. I was wondering why they had both versions, before I realized the plus stock legs are different than non plus stock legs. But, you live, you learn.
    J Dot
  5. crash1sttime
    Manchester UK
    Sorry mate still confused, all the auctions on eBay are for just a single leg for the p2v+ as I own the standard vision will I end up with 2 odd legs ?
  6. J Dot
    Sarasota, FL. USA!
    You are looking at part #18 p2v+
    You need to search ( part #16 p2/p2v )
    Like this link
    https://www.ebay.com/ulk/itm/221931626121
    Hope this helps, but yes if you order the plus version, you'll have mix-match legs. You need DJI PART#16
    J Dot
  7. J Dot
    Sarasota, FL. USA!
    :cool:
    J Dot
  8. crash1sttime
    Manchester UK
    Cheers pal, seems they are only available state side, none in the UK. Will give up on this idea I think, have you a answer on my question I asked via PM ?
  9. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    I use the plus skids on mine as they are taller . Plus I use the anti-static compass .
    Course ya got to use the V3 gps also if you do .
    Is good to see ya back crash :)
Similar Threads - legs old legs Forum Date
Foldable extended legs Classifieds May 25, 2014
For Sale: Carbon Fiber Foldable Legs Classifieds Nov 7, 2013
Will zip tying external 2.4 ghz antennas to the p3s legs interfere with the compass? Standard Dec 6, 2017
Phantom 4 camera showing landing gear legs Phantom 4 Help Oct 12, 2017
Small doors on rear legs of P4P General Discussion Oct 3, 2017
