new guy here
Discussion in 'General Discussion' started by Tigerfan, Dec 25, 2015.
  1. Tigerfan
    Christmas gift from the old lady -
    Got the phantom professional -
    Charged it all up - great first few flights, then recharged the battery and now the drone will not connect to my phone or iPad -
    I could use any and all help.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    What happens when you try to connect the drone?
  3. Tigerfan
    Sorry - not sure what you mean - the drone flys, the app works, it's just the camera says disconnected
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I was just looking for some additional information. Your original post was a bit vague.
    Try reinstalling the DJI GO app.
  5. Tigerfan
    I'll try it - thanks
  6. Reed L
    Alta, Ca.
    Make sure that you have both, the latest update and a working sd card. If it was on another battery then it may need updating also.
  7. kingovo
    You need to go in to your setting and open the developer menu (YouTube it) make sure debugg is on. When you plug in the phone to the charger you will see a option pop up on the phone for the usb charging click that and change it to send images...this had me confused for days and dji was no help..merry Christmas..
  8. Buckaye
    Orlando
    What firmware are you on? What iOS?
    Disconnect warning means that the app doesn't think it's connected to the controller. So it could be the wire (especially if you are using a non-apple wire)
    Also you might try re-linking the controller and the aircraft. I don't know why... but this worked for several of us that were having disconnect issues on an earlier firmware. You can see how to re-link in the manual.
    Good luck
  9. GlennG
    Try a different cable and make sure the USB is fully inserted. If you see DISCONNECTED at the top of the screen, your RC USB isn't connecting to the mobile device. I had same problem. New cable was the solution. Good luck.
    Suggest you calibrate the IMU before you fly since you updated the firmware.
Similar Threads - guy here Forum Date
New Guy Here Control (Go, Litchi, etc..) Jul 26, 2017
Total newb here - you guys rock - need to update my P4P+ first time Phantom 4 Pro Discussion Jun 24, 2017
New guy here Introductions Jan 7, 2017
New P3S guy here. Introductions Dec 31, 2016
Another new guy here... Introductions Dec 26, 2016
