new gps cable
belgium
hello,
After opening my shell of my phantom fc40, i saw my gps cable has been squized a little bit. Its the cable from the compass in the leggs. the grey cable.
one cable show a little bit of the inside of the cable. now i have no gps issue, but i am looking for a new cable, but found no one.
anyone know where they selle one?
Can it not be fixed without replacing it? Maybe shrink tube it?
Have you tried Google for parts?
If you just be sure the exposed conductor is not able to short to anything you'll be fine and will buy time till you find a replacement IF you choose to.
I don't think they sell the wire separate. I have not seen it anywhere at least. You could cut that part out that is pinched and re soder it together if it is that bad
Sent from my SM-N920V using Tapatalk
If everything is working okay and there are no broken wires I would leave it alone. The wires themselves are not broken from the sounds of your description. You could coat the bare wires with nail polish.
To go messing around with wiring that is not damaged can cause more faults.
shimuafeni fredrik
