New Gimbal twiching to the left, (solved)
Got the new gimbal cut a hole in the Phantom (perfect) first flight video came out fine, then replaced battery and gimbal was jerking to the left in flight, I found out battery was touching after putting powder chalk on the battery to see if it was rubbing the motor and it was, then I installed 4 washers between gimbal frame and Phantom, problem solved.
I hope this helps
Yes it is, give it a try and on another post someone said do the start up with it pointing north, but the battery was my problem
let me know.
Hello,
Thanks for the solution. Did you use longer screws? And if so, what size and where did you purchase them... meaning, did you get them from DJI?
Thanks in advance!
Rolf
