New firmware batteries update
Discussion in 'Pro/Adv Discussion' started by Buckaye, Aug 4, 2015.
  1. Buckaye
    Orlando
    I discovered this (that the batteries have a firmware update) after updating the new phantom firmware and switching to a different battery than the one I had used during the phantom firmware update... Just something I wanted to make people aware of because it freaked me out at first (I thought the phantom was going back through the update process.
    #1 Buckaye, Aug 4, 2015
    envisionabove likes this.
  2. kdrak
    after the aircraft firmware update and before you insert the next smart battery for update should you delete any feedback/result files from the microSD?
  3. Buckaye
    Orlando
    You don't need to... Works just fine if you do nothing with the output file.
  4. kdrak
    ^ thanks
  5. Buckaye
    Orlando
    You're welcome
  6. AmosMoses
    Illinois
    Two of my three batteries caused some sort of melt down with the update! It went through the normal sequence of beeps but on all but one it freaks at the end and just stuck on DEEEEEEEEEEEEEEEE. :eek:
  7. evang
    Same here!!
  8. Marcfly
  9. Marcfly
    I did the latest update.. then inserted a new battery , for the last 20 minuts I am having one long bip and two shorter one.. not sure what to do does this mean the update of the battery finished ?
  10. JohnK
    Hudson Valley, New York
    To the OP: what is the "this" you are talking about? This is why I don't want to do any updates. I have three batteries and really don't want to go through whatever "this" is.
    Mike Mauk likes this.
  11. Buckaye
    Orlando
    The "this" is that there is an update to be done. I have 5 batteries and each one took less than a minute to update. It appears to be part of the new firmware update package... if you don't want to do "This" then don't - but I don't know what a mismatch between the Phantom and Battery will do. I was just trying to inform the board that there appears to be a battery update.
  12. gfredrone
    Yes it's finished. Power off and put the next one in if you have more packs, then turn it back on.
  13. Bret Lucas
    5 batteries loaded with new firmware without a hitch. The process is as follows:
    After you have loaded the P3 firmware,
    1. Turn off P3.
    2. Turn on P3 and wait until the battery updates, should take approx a min.
    3. The middle two battery lights will flash to show battery is updating.
    4. Battery returns to normal light indication when upload complete.
    5. Turn off battery, remove and use the same process for the next battery.
    Quick, seamless, easy.
  14. gfredrone
    You forgot, badabing badaboom, GO FLY!
    Buckaye likes this.
  15. Tron_X
    NH
    Thanks for ^^This.
  16. Buckaye
    Orlando
    hmmm shouldn't be 20 mins for the battery... are you sure you completed the actual Phantom upgrade? It sounds like your Phantom is upgrading if it's lasting 20 mins....
  17. gfredrone
    It does the same tone after updating each batt as it does when updating the craft. It's done, move on to the next one. Rinse and repeat.
  18. AmosMoses
    Illinois
    Haven't had time to confirm this, work keeps getting in the way, but over in the Inspire forum they're saying that after the update it's recommend to cycle the batteries down the 5% to rest the smart board.
    Has anyone seen this in the release notes for the P3?
    Sent from my XT1080 using Tapatalk
  19. skyhighdiver
    South Dakota
    Mine went as smooth as a babies behind as well
    2 birds and 5 batteries all done in less than 30 minutes both pro and advanced controllers upgraded right from the app
    Bret Lucas likes this.
Similar Threads - firmware batteries update Forum Date
Updating extra batteries after initial firmware update Phantom 4 Discussion Jul 12, 2017
Firmware update for batteries? Phantom 4 Discussion Jun 22, 2016
Batteries gets hot during storage after firmware update? Phantom 4 Discussion Jun 3, 2016
dji - when do we P2 folks get a firmware update for our batteries? Phantom 2 Vision + Discussion Dec 16, 2015
If my batteries get updated to new firmware-and my drone isn't - will they work? Pro/Adv Discussion Aug 12, 2015
