New firmware and new owner questions!
Discussion in 'Firmware' started by TigardMikeR, Dec 2, 2014.
  1. TigardMikeR
    Hello everyone! Excited to say I've been enjoying my recently purchased Phantom 2 v.2 w/zenmuse h3-3d, gopro 3+ black combo! I even have my own ground station built I plan on sharing soon! But of course I have a few questions..
    The first is firmware upgrading. Is this a separate process for each piece of the Phantom? e.g. controller, ecu, gimbal? Should I upgrade the 3.08 firmware (fly aways and other glitches in mind), and how will this change my flying experience from straight out of the box?
    Secondly, are the course lock and home lock modes supposed to work out of the box or must they be activated? If so, are there risks involved with this?
    Thanks !
  2. Hughie
    Leeds, United Kingdom
    Enable IOC in the Assistant software. No risks associated with this as UP on S2 is IOC off. Home Lock is an important tool to have anyway as it will bring the craft back to the Home Point regardless of which way it is pointing.
  3. crash1sttime
    Manchester UK
    You need to enable Naza mode I think to get IOC, at the top of the assistant software it says Phantom, click it to change to Naza mode
  4. njet212
    Indonesia
    After enabled Naza mode, make sure your phantom got GPS signal otherwise you can't activated IOC
  5. Buckaye
    Orlando
    Just know that switching to NAZA mode gives you more options but also requires you to be a more accomplished pilot. Just make sure you are very comfortable flying the Phantom before you start flipping switches :)
    Good luck!
  6. Hughie
    Just make sure that you dont set S1 bottom position to manual. You probably *dont* want that at the moment.
  7. TigardMikeR
    Thanks for the feedback everyone, really appreciate it! As for the firmware im sure someone has some insight on this topic?
  8. Hughie
    RC f/w is upgraded using RC Assistant with the PC plugged into the RC.
    Everything else is upgraded via Phantom Assistant with the PC plugged into the Phantom.
Similar Threads - firmware owner questions Forum Date
Phantom 4 Pro & Plus owners... there is a new firmware upgrade! Phantom 4 Pro Discussion Jan 11, 2017
Professional New owner, any reason to stick to older firmwares? Phantom 3 Help Feb 12, 2016
Try in to update firmware.. Standard/4k Discussion Yesterday at 4:39 PM
P3 Firmware Firmware fail: [01886141][19 00] Firmware upgrade finish failed (step = 2, err = 0x08) Firmware Saturday at 4:45 PM
Complete Firmware reinstall? Standard/4k Discussion Saturday at 2:35 PM
